Searching_Ut's avatar
Searching_Ut
Fusing Solar Installation
This weekend, weather permitting I'm hoping to install 5 100 watt solar panels on the roof of my fifth wheel. The controller I'll be installing is a Bogart SC-2030 working in conjunction with a trimetric 2030. I have 10 AWG wiring I'll be running to a junction box on the roof for a parallel connection, then drop down to the battery compartment using either 6 AWG wiring on 4, depending on the route I'm able to take and how long that ends up being. My initial thoughts were to fuse each panel using a small automotive fuse block and 7.5amp fuses in the junction box, but now that I'm thinking about it, is there any reason to do this?
Looking over the panel specs, the short circuit output for the panels isn't much more than the normal nominal output which would more than likely result in any fuse I used that would handle the normal max output not blowing even if my wiring shorted straight to ground. Are there any gains to be had that I'm not thinking about? I'll put a switch in line between the panels and charge controller so that I can isolate it if desired, and I'll fuse the output side of the controller as I can see where there could be issues there a fuse would provide protection for.
I'm open to thoughts, ideas, or lessons learned by others the hard way.
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 11, 2025
