Rail_Dawg's avatar
Rail_Dawg
Fusing solar
If the controller is 30amp do you fuse the line for 30amps.
  • What brand controller do you have? Post all the facts, not just your question.
  • Morningstar says to comply with NEC the fuse (battery to controller) s/b rated at least 20% over the controller rating and wire should have ampacity to match the fuse. So you are looking at 40 amp fuse and #8 wire minimum afaik. Fuse s/b close to the battery not the controller. If you are pushing near 30 amps I would have #6 wire minimum assuming wire fits the controller lugs.
  • Fuses are to protect the wire between items. Fuse to the wire size. i.e. #10 30 amp, #12 20 amp, etc.
  • Doesn’t the controler’s manufacturer state the fuse requirements? WindyNation does.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
