MrWizard
Jun 06, 2014Moderator
Our fridge has been running from a Tripp lite pvc1250, for almost three years
Run power is approx 100w
Surge is approx 900w
This inverter will even power out MW, 1100 cooking watts...1650 input watts
westend wrote:
FYI, solar hot water heating is now required by code on Oahu, HI. The electric rates are unbelievable.
A 2000W inverter may not be overkill for an RV'er that wants to run a refrigerator, you have to have enough power to get past the lock rotor draw. It would be in the range of occasional microwave use, too. The Xantrex Prowatt 1800W inverter draws .8 amps at idle. A Prowatt 900W draws .6 amps.
