JacksonSigns
Apr 27, 2018Explorer
Thanks for the informative replies.
I will replace the part as soon as I can. On mine it means removing the inset cover that holds all the controls. I have to remove several parts to get to it. It will not come out the front because there is something holding it in. I notice the replacement part has a spring on the inside holding it in. Foam cover removed easily...but can't remove the other two items. Never make it easy do they?
Any suggestions on replacing the part other than disassembly?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
