wa8yxm
Apr 16, 2017Explorer III
Fastening Aluminum to aluminum or to non-metallic,, Use aluminum.. The closer the metals are to each other THE LESS galvanic corrosion
Alternative, depending on how strong the bonding needs to be NYLON
However, if they need to be electrically bonded.. Or IF A STRONG PHYSICAL bond (Which I suspect is your case) use aluminum.
You can also insulate the bolt from the panels, and still do electrical bonding.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
