I have a gas fridge that is probably 30 or 40 years old. I had gotten so I had to hold in the starter button for 2-3 minutes before flame would stay lit. I pulled it out to se if maybe the thermo co...
Well I think you found the problem. Replace the thermocouple.. Take the old one to a Heating and cooling specialist and see if they have one to replce it
Physically you need the hot end to match
Electrically you need the same connections at the control housing.
Cable length is "At least long enough"
Electrically they are most all identical so if it's a pysical match I'd anticipate good results.
