enblethen
Feb 03, 2016Nomad
If you have the small, 2.5 square thermostat, remove cover, locate the two wires going to furnace. Connect them together the furnace fan should start and then produce heat shortly. If this happens you have a bad thermostat.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
