bud01234
Feb 29, 2016Explorer
I may have missed it, but does the fan come on but there's no heat?
If so, then it's probably a circuit board or sail switch problem (neither one is really expensive and fairly easy to DIY.) Also, could be a bad igniter but you can usually hear the igniter snapping if operating.
If no fan blowing then, as was mentioned earlier, the burner won't light without the fan. Then it's a fuse or possibly fan motor problem and trying to light the LP.
