sleepy
Jun 06, 2013Explorer
Camping world has a hosw adapter called "easy fill" or something like that. To use a grill like you would at home you hva to Tee inbetween the propane bottle and the campers regulator to give you the pressure that you need... . the tubing from the tee that you use to connect your grill has to have another dedicated regulator just like the one you use at home when you have your grill hooked up to propane.
Or Lance camper has grills that connect to RV pressures
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 07, 2026
