ScottG
Feb 01, 2017Nomad
I just researched this very subject. I found that even with small Energy star rated fridges (9~10 cu/ft), you still need several times the power of a propane unit during the day to keep a modern electric fridge running. That means appx 1000 watts has to be replaced in your batteries every day.
If you have enough solar to keep up with that or you dont mind running a gen, you'd be fine but otherwise, you'' ll be running low on batt.
