brittsnbirds's avatar
brittsnbirds
Gas Quick Connector
Just purchased a 2014 Keystone Sprinter 5th wheel. I noticed that there is a propane quick connect under the propane tanks. 2 problems.
1. The tanks are on the port (left) side of the trailer. What was Keystone thinking? Why would you want it over there when most of your activities are on the starboard side?
2. What style connector is it? I have found that there are several different types. Tried emailing Keystone, apparently they don't reply to those.
I have tried several different types of connectors, cannot locate the correct one. Can anyone tell me how to figure out how to identify the type of male connector it takes?
  • Unless Keystone is doing something different than all of the other RV manufacturers Camco makes the standard adapter. They come in different lengths and some also include the valve adapter. I would just have it re-plumbed to the other side of the RV. Check out the Camco web site.
    Camco quick connect
  • I guessing it's a model 250, there should marking on it to verify.
