enblethen
Apr 03, 2016Nomad
Does the other propane appliances work?
Can you hear the ignitor clicking when you turn the refer on? Stand by the refer exterior access while helper turns the refer on to propane.
Does it work on 120 volts?
Check the burner area for debris around the burner.
Check the ignitor and flame sensor to make sure they are adjusted correctly.
Make and model of the refer?
