N147JK's avatar
N147JK
Gas valve.. Keep or Toss?
Hi, new member here. Had an odd episode with my Suburban NT propane furnace that has left we wondering.
Short story.. while cleaning the furnace, I inadvertently wired one of the gas valve solenoids backwards. The strange thing is, the valve remained stuck closed even after I switched the wiring around. So, I opened it up and found the valve slider under the solenoid stuck in the closed position. After freeing the valve slider and reassembling, the valve works perfectly again.
Question - the issue is I know these gas valves are "non-serviceable" but in this case, working on it seems to have fixed the problem. Regardless, should I toss it and buy a new one, or keep this one and move on? - Thanks
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
