N147JK's avatar
N147JK
Gas valve.. Keep or Toss?
Hi, new member here. Had an odd episode with my Suburban NT propane furnace that has left we wondering.
Short story.. while cleaning the furnace, I inadvertently wired one of the gas valve solenoids backwards. The strange thing is, the valve remained stuck closed even after I switched the wiring around. So, I opened it up and found the valve slider under the solenoid stuck in the closed position. After freeing the valve slider and reassembling, the valve works perfectly again.
Question - the issue is I know these gas valves are "non-serviceable" but in this case, working on it seems to have fixed the problem. Regardless, should I toss it and buy a new one, or keep this one and move on? - Thanks
  • enblethen wrote:
    Toss it! Not worth the chance of leaking or any problems with propane system.
    The coils are DC so no polarity issue.
    Thanks for the reply. Yes I'll most likely get rid of it.
    The solenoids have very clear polarity markings on top. I thought perhaps when wiring it backwards, the solenoid operated "in reverse", causing the valve to become stuck closed. Just guessing..
    Well I already replaced the gas jet and the burner, so might as well go all the way and get a new gas valve as well. Should be good to go for many years.
  • Toss it! Not worth the chance of leaking or any problems with propane system.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
