HslagExplorerApr 04, 2018Gc 10a 3e water heater replacementHow hard is it to wire the new gc10a4 into my camper mine the gas side is bad and element for 120 volt is frozen in and will not bust loose?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
Related ContentWater Heater Replacement RecommendationsAtwood water heater problemReplace insulation inside heater column.Water Heater Leak on start up.Suburban SW12DEL Water Heater On/OFF switch melts???
