tommykelly
Jun 01, 2015Explorer
I was the sad previous owner of a Generac 3400....you can download the service manual (use to anyway I haven't checked lately)..this gen set does things totally different from Onan...
Make sure your air filter is clean...if it is it is very doubtful the carb or engine is the problem.
it is a very complicated system....your gen. has a very sensitive control system.
and other than the r.v. dealer in Las Vegas knows how to trouble shoot the system I don't know who does...check with Sleepy he had his worked on in Las Vegas...
but just the basics....your Generator puts out approx. 650 volts.d.c. that feeds an inverter somewhere "inside" your camper...that is what controls the output to 110 volts. a.c. 60 cycles.
anything that it senses as a problem will shut your system down.
"If" that inside inverter gets too hot (and mine did) it will shut down...I had to remove the false bottom of a drawer to allow enough ventilation and no more shutdowns in hot weather.
You will get no support from Generac...pick your service man carefully...you will wind up worse than before...when it works it is great..but to make a compact unit that will work with the a.c. and the microwave on you need the 3400 watt unit..
Lance finally threw up their hands and went to Onan 2800 ..you just can't always use micro and a.c. at the same time...
but back in 2003 no one would touch Generac because they would not pay warranty..plus there is a big learning curve on that unit....
I had a loose wire that I found when I realized I would never get any warranty on the unit. but it would not even start...your engine is changing engine speed ( I am thinking) is trying to maintain 60 cycles..if it tries a few times to maintain 60 cycles and can't it will shut engine down..
One thing ..back then Lance made every effort to help me but had no luck with Generac.
that being said....good luck....
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
