Sagebrush
May 31, 2021Explorer
I do have a 12 volt oil drain pump thingie I got off Amazon, maybe it still works. Haven't used it in years. There is no access to a drain plug, if there is one under there maybe I can drill an access hole.
I figure the hose was removed from the filler side to drain. The hose clamp is out of position on the back side of the filler port thing. The whole bottom pan is gummy/sticky with oil. But the motor is itself looks dry. I've never owned a Generac 40G, so its a learning curve. It doesn't supply power consistently, it needs a new 30 amp breaker I think. I flip the old breaker back and forth a few times and it will work for a while. Of course it ran perfectly when I bought the trailer, then 5 hours of run time later it started acting up.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: May 23, 2026
