Chris_Bryant
May 01, 2014Explorer II
Don't know about Generac, but for Onan, if you are blowing VRs like that it points to bad brushes/slip rings. The rings get tarnished enough that the VR has to put out very high excitation voltages (the voltage regulator feeds dc power through the brushes to the rotating rotor , which spins past the stationary stator coils. Higher DC in to the rotor makes higher AC out of the stator, but bad brushes or dirty slip rings cut that voltage down.)
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
