jcbinky's avatar
jcbinky
Generac 75D
Hi All, I have a 2005 Damon with gaurdian 7500 diesel genset, I unplugged from the house and fired up genset, turned on both AC's and waited a bit everything seemed fine. without thinking I hit the switch in the bedroom and shutdown genset under a load. dumb... I turned off AC's and started Gen Backup, turned on AC's and left them to cool down the coach walking to garage heard genset start to drag down almost sputtering, and coughing, then it ran back up to speed, went into coach looked around and found rear AC had flipped breaker. I reset the breaker AC seemed OK so I shut all down and quit for the day, went out early this A.M did some cleaning, started Genset engine runs fine but no power. checked at the switchgear and only getting 42 V With 60Hz on both poles of genset connection. Help!!!!!!!!!!! Any Ideas????????? only 90 hours on Genset and 15000 miles on coach.
No RepliesBe the first to reply
