bounder39zman
Nov 05, 2017Explorer II
This model Generac does not have a built in transfer switch (dont know of any RV type of generator that does). If the generator output wiring is not isolated from shore power line by either a manual or automatic transfer switch, this is extremely dangerous. This generator "excites"
the field during engine cranking to start voltage build-up by the control board providing 12 volt from battery to field. when voltage comes up to approximately 100vac, a relay on control board disconnects starter circuit, and field flash, the voltage regulator takes over providing field voltage to rotor.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
