hedchange
May 21, 2015Explorer
Ok after some more testing.
All the static inverter test were OK again
Power supply test from the generator to the inverter was in spec for the circuit breaker off and on.
The 9 wire testing with the generator on and circuit breaker on were all in spec.
The DC voltage coming off of the red blue and black wires were all in spec.
red-blue =375v
black-red = 185V
black- blue = 186V
So I know that all the correct information is getting to the inverter but not sure if the control board is reading it in the generator.
The inverter still only puts out 19-20v AC and the fan does not come
-some background on the unit. This came from a camper that is owned by my grandfather. The generator has 78 hours on it and the inverter is new. When they bought the camper the generator had issues with supplying AC so they brought it to a shop and they said the inverter was bad. It was replaced. After being replaced it had worked for 2.5 hours and then it stopped.
My grandfather tried to get it fixed again but the tech said it was not the inverter, that it was good.
He took the generator out and replaced it with an onan. on.
red-blue =375v
black-red = 185V
black- blue = 186V
