hedchange
May 22, 2015Explorer
Checked the ats and it is not functioning. I ham going to return it under warranty and wire the shore power back into the control panel. Still working on coming up with a plan to check.
Going to double check the polarity on the dc link again as I did not take note the first time I checked. I only looked at the output which the absolute number was in spec,
Going to check the pcb. I should be able to get to the top without removing the generator as there is a good six inches above the unit.
Thanks again for any input.
EDIT: the polarities were good and they were the correct voltage
