hedchange
May 24, 2015Explorer
Ok quick update. I dug into the generator (good thing the box is big enough to get into the top without removing it). I found the circuit board and unplugged the connection to the diodes to check. Everything looked ok. While I was in there I actually took off and reseated all the connections several times. Went back into the trailer with the breakers off and noticed the fan was running I. The inverter. Turned on the circuit breaker and am now getting 120v. Plan is to get in there tomorrow and clean the terminals as much as possible and stick DG into all the connectors so the line don't oxidize or build corrosion . Thanks for the support and having a place to voice concerns and get problems fixed.
