Alfred622
Aug 29, 2014Explorer
Do you have any other propane item that is fed from the same regulator that is supplying the generator? For example, if you start your stove burner on high, does it burn brightly but after 6 seconds it sort of peters out?
I think your problem smells like a fuel problem - possibly a regulator. You do have a reasonably full tank of propane....right?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
