I have a Generac prime pack generator. I have change the selonoid but yet I try to start it all it does is a little grinding spin would not call it a spin turn real slow.also new carb.
I don't know your gen. Now I would pull the spark plugs and then see if it will turn over better. That would get the pressure off if any gas has gotten in the cylinders. Or if you can get your hand to the flywheel and see how hard it is to turn. If its not to hard by hand with the spark plugs in you have a bad connection or low or bad battery.
