rjstractor
May 23, 2023Nomad
CA Traveler wrote:
Is it OK with the box off? Point the hot exhaust straight up through the top not down. Shield the serving side only.
This. Run it with the box off and you'll know soon if that's the issue. Another simple, free thing to check is to ensure the correct oil level. Very simple thing, but it will cause the issue you're describing.
And, based on the name of your food truck, I very much want to try it! Too bad I'm not in your area!
