BrisketBiscuit
May 25, 2023Explorer
Thanks all for the responses. I think the issue was insufficient airflow at the intake end. It was pretty open and had the small fans, but the built-in blower wasn't flowing nearly as much as without the box. I cut out everything below the slot at the top of those fans and braced it back up with some scrap perf/slot angle. I attached a couple pieces of acoustic foam to it like curtains (so I can still reach the choke/fuel valve), and drilled a few ~2" holes on the back face. Along with changing the exhaust pipe to point up, it seems to be happy now. Ran for ~4 hours last night with no problems, hopefully it will be the same in warmer weather.
