Ikster's avatar
Ikster
General 3500 XL Shuts Off
My Generac 3500 XL was running fine last month. Now it starts up, runs smoothly only if about 45% chocked and then the low oil light comes on and it shuts down. The oil level is fine, but I changed it just to eliminate problems with the old oil. Admittedly it doesn't get much run time. We used it for several hours last month and we did fill it with fresh gas then. If the oil sensor is bad then how do I replace it?
  • Did you drain the bowl on the carb or shut off the gas and let it run till the gas in the carb ran out? If not the gas may have evaporated and left shellac in the jet. Not enough fuel flow to run with the choke off.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
