Lexicon7 wrote:
WestEnd ::: sorry to say, I am having difficulty following you on the "house" power / inverter issue I brought up... I like that site and have come to respect the Xantrex name...
For shear convenience, you think it would even be worth it? I suppose I could just rig a 4 place junction box on the end of a living area length extension cord... Can't wait to get out of here and start putting all this to the test. I'm sure I'll never stop tweaking stuff..
I was posting about using a transfer switch to power your receptacles when away from shore power. In the situation of a truck camper, it is probably more convenient (and less expensive) to just plug a multi outlet surge protector into the inverter and mount it somewhere convenient. That is how mine is now but I will be installing dedicated receptacles (a couple) that run just with the inverter. Then again, if I get an urge, I may just use the 15 amp transfer switches. It's about how clean an installation one wants and the convenience of not shifting plugs.
