Lexicon7's avatar
Lexicon7
General RV Solar Questions?
I'm planning to add a couple of new high end Kyocera 140 panels and build up a new system out of them. Currenly I have what my old 95' Squire 400 came with which is a substandard and smaller panel with an ACS Specialty Concepts Controller. This unit has one red light and no digital readout. It does keep the single 12V house batt charged and that according to Lances typical (and also probably substandard) idiot light array monitor.
I have no experience on solar but have been researching for a year or so and doing a lot of reading and on line window shopping. My thoughts are to begin the learning process by adding a better charge controller and an inverter since there does not seem to be one now.
I am aware that panels must be matched but I an considering (roof space allowing) leaving the existing system for "house" use and adding the new system with a huge inverter and of course components to match.
That being said, I need to determine the power coming from the existing charger before doing anything. Is this correct?
Also, how exactly can I do that to get a legit reading?
I assume I can get a reading in the fuse panel where the lines from the existing controller enter. Is this correct? I have a good meter so this should not be a ploblem, just correct procedure to get started?
Any assistance greatly appreciated. Morgan
  • 3_tons's avatar
    3_tons
    Explorer III
    ASC controllers are very simple thus reliable, though basic and of a single stage PWM type. To start (what I have done), you could enhance your present ASC system by adding a in-line shunt in the ASC's output which will allow taps for a separate digital amp meter.
    Future expansion could be made with a parallel solar system (with dedicated controller), inverter, and if you like, add another 500amp shunt in the Batts neg cable for a stand alone smart meter like a Trimetric or Xantrex LinkLite...In this way, you'll see what either system is harvesting real-time (separately or combined), and total amps both in & out of the Batts...
    Here's a link for a Shunt:
    http://www.bestconverter.com/search.asp?keyword=shunt&search.x=11&search.y=10
    3 tons
  • Voltage from output of 'controller' would tell you its output. If tying new and old panels together you want to measure and match voltage output of the panel itself, before controller or regulator.
  • Thanks Bear, you know, I have that site on my desktop! I'll take a closer look.
  • For a good source of RV Solar info go to
    http://www.jackdanmayer.com/
    He knows solar and RVs
Having RV issues? Connect with others who have been in your shoes.24,335 PostsLatest Activity: Nov 09, 2025
