wa8yxm
May 30, 2019Explorer III
If it is installed in a motor home.. Well min MH is a gasser
I can carry 70 gallons of gas (Full tank) and use 3/4 of that for the generator (or just over 50..1 quart over about).
Propane I carry 27 gallons. Tops
Some diesels carry well over 100 gallons and can use 3/4 of it for the generator.
I try to keep tank at least 1/2 full in case I need to use generator by the way. I'll put 20 gallons in when I pull out of here and use Genny (Monthly maintenance run) on the way to the next CG)
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
