2oldman wrote:
For your described use I would suggest 4 batteries and a 2kw pure sine inverter. That should run the MW much easier than a generator, and you can recharge at your leisure. Heck, you can be charging at the same time.
How I'd do it.. or have done.. sort of.
2000 watt Inverter generator powers most of the incidentals in the RV via a Progressive Dynamics 9180 with wizard... About the only thing that gave it pause is my 750 watt coffee pot. (long story)
The inverter/charger I tripped the 30 amp breaker feeding it manually (Turned off) so it powered electronics (IE: this laptop) Coffee pot. Microwave. Electric oven et-al (In short almost everything save the fluorescent lamp in the bedroom). 100' 12ga to a 20 15/20 amp outlet (not sure which breaker)
2000 watt Trusine.
For some reason it did not have enough battery power to make coffee in the am but if I hit the BOOSt button on the Wizard I had no tribble.
Did that for about 2 months.
Worked.
