So...being electronically "challenged" I have a question about amperage on the smaller generators like the Honda 2000. Specs cite 13 amps max. Will this damage things like the convertor and inverter i...
No. The generator only needs to produce the amps that the loads are drawing. If you're only using 10 amps you only need a generator that will make 10 amps. If you try to pull more than the 13 amps the gen. is rated for it will overload and shut down. This still shouldn't damage anything.
