SHExplorerJun 04, 2017Generator AmperageSo...being electronically "challenged" I have a question about amperage on the smaller generators like the Honda 2000. Specs cite 13 amps max. Will this damage things like the convertor and inverter i...Show More
wa8yxmExplorer IIIJun 05, 2017Amps are like Gallons per minute.YOu have a "Mister nozzle" on the end of a hose, it only passes about a quart a mintue.YOu have a garden sprayer it passes 5 GPM When hooked to the same hoseYou take the adapter off and the hose passes 10 GPM.It is all up to the "Load" how much is produced.MY converter draws about 10 amps tops.. it's an 80 amp converter so that honda would not even be at full output with it.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related Content7 pin plug amperage rating?A/C amperage draw?Generator noise reductionGenerator operationAC getting amperage spike after an hour use.
