Ls1adam's avatar
Ls1adam
Generator and ac
Question, I have read some topics on this. I finally go my ac to come on with the generator. I don’t know if I have a 13.5 or 15k unit. It is central/ducted unit.
I have a 3200/4000 watt generator. I plugged in and got the ac running but the generator pulses when the ac is on. When I turn it off the generator runs smooth.
Is the generator to small?
  • j-d's avatar
    j-d
    Explorer II
    By the outlets, sounds like you have a "jobsite genny." 4000 Start/Surge and 3200 Running Watts. But that is AT 240 VOLTS plugged into that one four-prong outlet . Anything plugged into a 120 outlet is limited to 2000 Start/Surge and 1600 Run. That's sketchy with a 13500 A/C.
    Somebody help if I'm wrong here. Make/Model of this 4000/3200 genny would help.
  • I think a 3200 or 4000 watt generator should run either a 13.5K or 15K A/C unit without a problem. I've run my 13.5K using a 2400 watt generator. The occasional surge or "pulse" may be occurring when the A/C compressor kicks in.
  • Wow didn’t know it could make it do that with it running great at idle
    I’ll try cleaning the jet
  • Ls1adam wrote:
    With something like. Skill saw or the like it does fine or with no load it runs really smooth
    Like said above, carb jet restriction would do that. Cheap, easy and fast way to fix it is a dose of Seafoam. Odds are slim it will work, but sometimes it does and it’s much easier than taking it apart.
  • With something like. Skill saw or the like it does fine or with no load it runs really smooth
  • Ls1adam wrote:
    Yeah I though so too
    Yes it can’t idle smooth, it’s like when a car has a vacuum me leak and the idle goes up n down
    That's called a lean roll. The main jet could be restricted.
    Richard
  • Do the plugs on the generator need to be rated a certain amount?
    I have 4 outlet of 120
    And a 4 prong 240
  • Yeah I though so too
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Possibly or But I'm not sure what you mean by "Pulses" do you mean it surges or it runs harder when the Compressor kicks in.
    YOu may need to make a minor adjustment to the generator is all.
    To find out if your A/C is 13.5 or 15K 2 methods
    Of the 4 units I have had 3 you remove the grill inside and LOOK UP
    The 4th one the sticker is on the side of the topside unit
Having RV issues? Connect with others who have been in your shoes.24,260 PostsLatest Activity: Jun 02, 2025
