DrewE
Feb 01, 2019Explorer III
Dirtclods wrote:
As mentioned change the oil and I would add the filter too! This helps with the longevity of any motor.
Quite a few small engines do not have an oil filter. Obviously it's hard to change one that doesn't exist.
If you have an oil filter, then changing it as a part of the oil change process generally makes sense to me. You also likely don't need to change the oil as frequently as you would otherwise (though initial break-in is somewhat of a special case).
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
