SHRED's avatar
SHRED
Generator breaker keeps shutting off immediately
1995 Lazy Daze.
Onan generator.
Progressive Dynamics PD4645 converter.
There is no power reaching the motorhome from the generator.
I tested the leads to the breaker. One read about 170VAC with generator running. I shut the generator off and tested the other lead and it tested .266 kilohms so I don't think there is a short but I'm not very electrically literate.
I replaced the switch. That didn't fix.
AC voltage works fine when I plug into shore power.
I'm wondering what next to check.
Thanks.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There are shorts you can't find with a VOM. They are voltage dependent.
    Alas I can not list them all but I can tell you now to narrow the search
    INSIDE the RV turn off EVERY breaker. not fire up the generator. Turn on just the MAIN breaker... Still good (hook a test light or volt meter to the main braker and white bus to check or have partner watch generator breaker)
    Ok turn on the next breaker, and the next and the next till CLICK.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 22, 2026
