stubpup11's avatar
stubpup11
generator choke problem
I have a generac NP52G in a 94 gulfstream class C. The electric choke was replaced and appears to function but the linkage to the float butterfly keeps slipping off or past the end of the choke linkage. The choke activates but won't pull the butterfly closed thereby causing the engine to crank excessively before firing.
Anyone fight this battle? How did you fix it? Can I bend the linkage without altering it's function?
  • My Generac, a 5.5kW unit had a problem with the choke closing when starting also. The solenoid was was trying to close the butterfly,but was unable to do it. Upon checking it, I would just tap it and it would close. I noticed that the plastic cover over the solenoid was against the the linkage. Placed a spacer to move it out a little and have had no problems since. JMO
  • j-d's avatar
    j-d
    Explorer II
    Several OP's here are members of the Smokstak Forums and this link is to the Generac section.
    Most of us here seem to have ONAN gennys. A few have Generac so don't feel alone. Still, Smokstak may offer more help sooner.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
