- What is the expected use? Any specific concerns?
- Wayne_DohnalExplorerHere's one source for a propane conversion for the Honda http://www.generatorsales.com/order/Honda-EU6500iSA-Tri-Fuel-Kit.asp?page=Honda_EU6500iSA_Tri_Fuel_Kit .
I run my eu2000i from propane and gasoline. It works, I do have to fiddle the propane mixture adjustment some for light vs. heavy loads. - MrWizardModeratoris either one water/liquid cooled
it will be quietest one. - Glenn_And_KittyExplorerOriginal poster: Thanks for the input so far. I forgot to ask in my original post: Would anyone know if either or both can be converted to run on propane as well as gasoline?
- carpetguy2ExplorerHeard that the troy built generator is the best then the honda.
Price wise I am not sure. - SWDExplorer
mlts22 wrote:
Both are top of the line inverter generators. I'd probably go with the Yamaha because it is less expensive.
X 2 - mlts22ExplorerBoth are top of the line inverter generators. I'd probably go with the Yamaha because it is less expensive.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
