Cougarnewbie's avatar
Cougarnewbie
Generator comparison
I am looking at the 2000W Champion inverter/generator. It is cheaper than the Honda or Yamaha. Curious if it is good enough? I understand no A.C.. My cougar is 30 amp hook up. With adapter will it run my PD converter?....Hey moderator, we need forum to compare common products without violating the buy and sell policy.
  • Almot's avatar
    Almot
    Explorer III
    What we need is a good 101 or FAQ. Education, in other words.
    Any generator will run any converter. Will your PD run your 12V loads, or will your generator run your 120V loads, is a different matter.
    2000W is normally enough for things other than A/C though.
  • You might also look at the Generac iQ2000,less money than the Honda or Yamaha Quietier and will run the same things,PD included,no problem on a 30 amp RV,microwave,TV etc NO A/C.
  • if you had done a search, here in Tech Issues, you'd have found a Champion 2000 thread with HUNDREDS of posts.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
