j-d
Mar 09, 2017Explorer II
Does the genny produce 12-VDC to recharge its starting battery? If so, I'd consider an electric pump, along these lines
The common pressure is 5-7 PSI but there's also a "low pressure" version (3-5 if I remember) version, that I used for the ONAN on a coach. You'd need a Primer Button switch to fill the carburetor before you start the genny, if it's been standing awhile.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 17, 2026
