dougrainer
Jun 06, 2021Nomad
jimdmorrison wrote:
So the previous owner had put the wrong fuel pump on. I replaced that, so I think that solved the gas issue. Still having a weird issue with the oil pressure. I drained it and I can only get half a quart or so in. It’s weird that it builds oil pressure.
The reason I asked is simple. ONAN fuel pumps even tho they LOOK like other aftermarket fuel pumps are LOWER PSI pumps. So, people buy and install that CHEAPER than Onan fuel pump with the higher PSI and they may have problems. Not always, but you have an unusual problem. Remember ALL the fuel pump does is force GAS to the Carb bowl. THEN the Float needle jet opens and closes the fuel to the bowl. IF you have TOO MUCH fuel, then the Onan will not run(flooded). So, HOW do you think the fuel is getting to the Crankcase? Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
