Racer18
Mar 08, 2019Explorer
Generator Info
What is the quietest 3000 generator on the market and the best for the dollar? Looking to parallel 2 of them together.
map40 wrote:Very cool! Yeah, making your own parallel "Kit" is real easy, and cheap.
As a matter of fact, once for a Relay for Life event we had 3 RVs (1 A and 2 Cs) and 4 Inverter generators. We bridged them ALL and connected the RVs to them (Gen 1 - C - Gen 2 - A - Gen 3 - C - Gen 4). We were able to shut down one at a time, refuel, let it rest and restart and move to the next without a glitch.
Of course, we had to make our own parallel adapters, which took all but 30 minutes.
map40 wrote:Wow. I would think too many people doing that would put a serious dent in their bottom line.
Warranty is $130 for 2 years. They tell you in the store just to bring it in before it expires. I did it, 2 times, 2 generators each, no questions asked. Just empty the gas tank.
2oldman wrote:BFL13 wrote:From my research I see only a 30a socket.
How did you connect your 50a shore cord? Confusing earlier posts about receptacles, etc. What exact receptacles are in the Predator's parallel kit?
2oldman wrote:map40 wrote:Sounds too good to be true.
.. you buy the 2 year extended warranty and in 1 year 11 months and 29 days you trade it in for a new one. You buy the warranty again and so you go...
BFL13 wrote:map40 wrote:
The best deal for the money is the predator 3500. Really low noise and you buy the 2 year extended warranty and in 1 year 11 months and 29 days you trade it in for a new one. You buy the warranty again and so you go...
The run just fine and they are parallel capable. As a matter of fact, you can connect them to Ryobis or other parallel capables, even while running.
I used to run my 50 amp motorhome with 2 3500. I had the 3500 in parallel, turn on both AC units, and my buddy's TT connected directly to one of the generators 30 amp plug. The run both RVs with no problem.
How did you connect your 50a shore cord? Confusing earlier posts about receptacles, etc. What exact receptacles are in the Predator's parallel kit? Your buddy plugged his 30 into one of the gen's own receptacles while you plugged into the kit? More details please- I don't have 50a and find it hard to follow how it works.
