TucsonJim
Jun 09, 2016Explorer II
I have had the same Honda generator for 11 years now. Here are some things I do.
-Change the oil every year.
-Change the spark plug every other year.
-Clean the air filter every second time I fill the fuel tank.
- Add StaBil fuel conditioner to the fuel each and every time I fill it up. This is probably overkill, but it's easy to put the generator away and forget to treat the fuel which will eventually go bad. Stabil will protect your fuel for a year or more.
-Shut off the fuel lever and run the generator out of fuel if it won't be used for more than a month. This will run the carburetor out of fuel and prevent gum-up. This is really important if you don't use a fuel conditioner like Stabil.
Jim
Jim
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
