dougrainer
Jun 12, 2014Nomad
Rjensen726 wrote:
I have a Cuumins QG4000 gas unit and generator is not charging the Gen battery on my unit either. Isn't there an alternator in the genset to charge the battery? My application only uses 120v appliances and lighting. There is no external charger connected to the Gen battery.
NO, Most Gensets do not have a charge system, especially RV designed Gensets. Powertech gensets, you can order an optional charger module that is just to keep the battery up from the 12 volts used by the genset. You need to just get a battery maintainer type 120 charge module to keep your battery up. Doug
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
