bgitler
Apr 17, 2015Explorer
Generator not making a sound
I have an onnan 4000 generator. Yesterday I pulled my motorhome out of storage and everything started up great except for the generator. I pressed the start button and the light on the switch blinked 3 times, but it seems like it has always done this. There was no clicking sound like it would normally make when it is trying to start. I pressed the prime button but again there was no clicking sound and the light on the switch did not turn on.
Now whether I press the prime button or on button nothing happens. One time when I pressed the prime button it lit up briefly but then turned off again. It seems like the generator is not getting enough power from the coach battery, and possibly not getting any at all since now there are no sounds and the light on the switch does not turn on. However, the battery does have enough power to open the slideout so it isn't dead.
I also found the fuse rocker switch located on the side of the unit. I moved it to the opposite side and then back again but this did not appear to do anything.
Also, I've read about low oil being an issue and I did change the oil to rule that out so it shouldn't be a problem. I used about a quart and a half.
Thank you so much in advance, very frustrated right now!
