lc0338
Jun 28, 2017Explorer
NoJive wrote:
Well, the generator has always been loud, but it no longer throttles up in response to loads, hence it now can no longer run my microwave, which it used to run fine.
Sounds like your generator needs some adjustment. Some microwaves are very picky about the power (60hz). Your type generator normally runs at 3600 rpm to generate the proper power. I have read that some service locations put about a 15 - 25 amp load on generator and adjust to 3650 rpm. Best would be to take it to a service location and maybe have the oil changed as well. You could damage some electronic equipment with under/over voltage.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
