MrWizard
Jul 15, 2017Moderator
that generator will always run at 3600 RPM. 60hz
if the freq is correct the speed is correct
it will get louder and use more fuel with a load
but it is still the same speed plus or minus 2hz / 120rpm
if it won't carry the load
A: the load is too big
B: the generator is failing
open the end of the generator head and check the field brushes on the slip rings
