PaulJ2
Jul 17, 2017Explorer
NoJive wrote:
Ok, finally got to do some testing. With no load, I get around 117 volts, with a hair dryer running on max, I show 122 volts. Here is a video I took:
https://youtu.be/283RcOO75mo
After hearing the audio the generator's governor is not controlling the engine speed properly. It should stay at 3600 with increased load. The voltage increasing with the rpm decrease is the regulator over compensating for the speed drop off.
I believe the problem is with the engines governor.
