NoJive's avatar
NoJive
Generator not putting out enough wattage...I think
Newbie here, but I am posting because I cannot find my exact problem anywhere else. All I am finding is low voltage or no voltage issues.
I have a Harbor Freight 4000 watt (3200 watt running) generator that we use for camping, and power outage purposes. I've had it for around three years, and it has given me no problems except for noise (it is loud!). Anyways, we are camping on our river property this month, and I noticed the generator running faster than it normally does. We use it to run the A/C as needed, and it seems to idle down once the compressor kicks in, and then speeds up once that kicks off. That seems like the opposite of what it used to do. I also found out that it now no longer runs the microwave, which it used to do fine. Now, the generator bogs way down, and the microwave barely runs.
I did call Harbor Freight, and they seemed to think the voltage regulator was going bad, so I bought a new one, but that didn't seem to help any. I'm getting 116v on the outlets, so it doesn't seem to be a voltage issue.
Is there anything else I can check?
    Is that with the troublesome load connected.....or not ??
    P.S. In the 3 years of ownership, was there any extended periods of non-use ? If so, did you put stabilizer in the gas ??
    And it is a good idea to give it a healthy dose of a good carb cleaner every 6 months or so. Berrymans B12 Chemtool is probably the best product on the market; Gumout is a close second. SeaFoam is a distant last.
  • The governor....I did some Googling just now, and that may in fact be the issue. I will look into that, and report back!
  • It sounds to me like the governor for the engine isn't working properly or smoothly. It might be something as simple as the mechanism binding or being dirty. It could very well also be the carburetor needing to be cleaned or some other general small engine repair/adjustment.
    Pretty much any small engine repair place should understand the engine (if you don't feel up to checking it yourself); they're pretty much bog standard small engines, such as would be used on lawn mowers or whatever. Parts availability may be a bit limited for the Harbor Freight units, though they at least tend to have some support available.
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Nov 30, 2025
